This command clears all IS-IS counters for the specified router process or all router processes.
| area_name | Specifies the router process for which counters are cleared. |
| all | Clears IS-IS counters for all router processes. |
N/A.
The following counters are cleared: corrupted LSPs, LSPDB overloads, manual address from area count, LSP sequence number wraps, LSP sequence number skips, LSP purges, partition changes, SPF calculations, authentication type failures, authentication failures, and ID field length mismatches.
The following command clears the IS-IS counters for areax:
clear isis counters area areax
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
